[Qgis-user] Install Qgis on Ubuntu 14.04
custard custard at westnet.com.au
Sat Jun 14 22:44:29 PDT 2014
On 15/06/14 13:12, Andre Joost wrote:
> Am 15.06.2014 06:12, schrieb Ramon AndiƱach:
>>> On 15 Jun 2014, at 3:09, Andre Joost<andre+joost at nurfuerspam.de>  wrote:
>>> I guess the SDK 5.1.1 version is not comaptible with the gdal build
>>> script and source file.
>> Which is annoying.
>> It also brings us back to, "For the purpose of the original question,
>> will the old 3.3 SDK be adequate?"
> Is it still available? Intergraph does not provide it. And
> <http://de-mirror.org/distro/gentoo/distfiles/libecwj2-3.3-2006-09-06.zip>
> does not work anymore.
Yes. Both these seem to be working.
http://www.kyngchaos.com/files/macosxport/libecwj2-3.3-2006-09-06.zip
http://mirror.ovh.net/gentoo-distfiles/distfiles/libecwj2-3.3-2006-09-06.zip
I'm getting a build fail at a different point too you, but that's my
fault. I forgot to say that you'll need libgdal-dev too (which gives you
gdal-config).
-ramon.
