[Qgis-user] KML Load Error
James Wood jwood911 at gmail.com
Sun Jun 15 17:57:44 PDT 2014
​Thanks for taking a look at this guys. I think you both confirm for me the
suspect source file is the issue. It's not a deal breaker, would just be a
nice layer to have for some analysis. There may also be another source
somewhere... haven't dug much on that end of the problem yet.
Thanks again,
James
On Sun, Jun 15, 2014 at 7:40 PM, Simon Cropper <
simoncropper at fossworkflowguides.com> wrote:
> On 16/06/14 10:20, James Wood wrote:
>> Seemingly a newbie question, and I confess, KML is not something I play
>> around with very much, but I'm getting an error on a simple Add Vector
>> Layer operation with a downloaded KML file. I suspect it may be the
>> source, although a quick peak in Notepad++ looked OK. The links  (mostly
>> to PNGs stored online) that I checked inside the doc are broken, but
>> would that cause it not to load at all? Would anyone else want to give
>> it a quick try?
>> KML Source: http://www.unhcr.org/pages/49c3646c4d3.html
>> QGIS 2.2 on Windows 7 x64 (install from standalone)
>> Some options here
>> <http://gis.stackexchange.com/questions/33826/how-to-
>> convert-kml-to-shapefile-without-losing-attributes>
>> for me, I guess, if it works for someone else.
>> Thanks in advance,
>> James​
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> James,
> I can't get the KML file to open either (QGIS 2.2, Ubuntu 13.10)
> Have you tried just running the KML file from Google Earth?
> The errors I am getitng suggest some non-standard colour tags are being
> used. If you can open in Google earth try exporting to a different version
> of KML.
> Cheers Simon
>    Simon Cropper - Open Content Creator
>    Free and Open Source Software Workflow Guides
>    Introduction               http://www.fossworkflowguides.com
>    GIS Packages           http://www.fossworkflowguides.com/gis
>    bash / Python    http://www.fossworkflowguides.com/scripting
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140615/26809b66/attachment.html>
