[Qgis-user] QGIS-Server write log on stdoutput ?
Larry Shaffer larrys at dakotacarto.com
Sat Jun 21 11:53:02 PDT 2014
Hi Andrea,
You can set the QGIS_LOG_FILE environment variable to have the
qgis_mapserv.fcgi process log to a file. It needs to be set within the
server process environment (if it has a loadable FCGI module) or within the
FCGI-spawning process environment, e.g. uWSGI or spawn-fcgi.
For Apache:
<IfModule mod_fastcgi.c>  (or mod_fcgid.c)
  SetEnv QGIS_LOG_FILE /path/to/qgis_server.log
</IfModule>
Of course, the log needs to be writable by your Apache or FCGI-spawning
process user.
NOTE: if using latest master builds (or upcoming 2.4 release), the env var
is now QGIS_SERVER_LOG_FILE, with the new env var QGIS_SERVER_LOG_LEVEL to
define verbose level [0,1].
I haven't tested this, but the amount of debug output is usually relative
to the CMake build type, e.g. Release vs. RelWithDebInfo or Debug, like is
the case for the QGIS desktop output. Pretty sure that is always a
compile-time choice, and can't be be overridden at run-time. Your
qgis_mapserv.fcgi binary may need to be (re)built as RelWithDebInfo or
Debug to trigger enough output to debug your issue.
[0]
https://github.com/qgis/QGIS/commit/29c39b9f0209ddedd0d51eda1dc926e6e0f2ea9e
[1]
https://github.com/qgis/QGIS/commit/bdf1ac8d46d89869e58884c5f55ff711a1f5f76d
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Sat, Jun 21, 2014 at 9:25 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> Our qgis-server is crashing on a project .
> This is quite strange because on the same project on a qi-desktop (on
> another machine) it run without any problem.
> And also the qgis-server run without any problem with another different
> project.
> I try to read from the log of server web to see any useful information
> but the log none report of qgis.
> The web server ,og come from the stdout so perhaps there is some
> specific setting to say to QS to output to stdout log ?
> Thx,
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140621/6afcf504/attachment.html>
