[Qgis-user] SAGA toolbox
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Jun 26 04:13:56 PDT 2014
Hi John,
I've had this myself in the past. It's a result of the way it has been
installed - are you using Windows or Linux? And what version of QGIS?
Sometimes the builds for Windows don't include them though I was under the
impression this had been fixed.
Cheers,
Jonathan
On 17 June 2014 22:41, john polo <jpolo at mail.usf.edu> wrote:
>  Greetings,
> I have SAGA installed and apparently enabled when I check
> Processing>Options and Configurations>Providers. However, I get the error
> msg
> "Missing dependency.This algorithm cannot be run :-(
> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA
> is not installed in your system, or it is not correctly configured to be
> used from QGIS"
> when I try to use the Terrain Analysis - Channels tool.
> Can someone tell me what I am doing wrong, please?
> John
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain confidential, sensitive or personal information and should be
handled accordingly. Unless you are the named addressee (or authorised to
receive it for the addressee) you may not copy or use it, or disclose it to
anyone else. If you have received this transmission in error please notify
the sender immediately. All email traffic sent to or from us, including
without limitation all GCSX traffic, may be subject to recording and/or
monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140626/09ce4a6e/attachment.html>
