[Qgis-user] QWC strange behaviour of Zoom and Pan functions if authid=EPSG31467 and problems with long directory paths in qgis-mapserver
landconsult at freenet.de landconsult at freenet.de
Fri Jun 27 07:27:12 PDT 2014
Bernhard, Marco,
Bernhard, your proposal to change the xy order in GlobalOption.js was right, ZOOM and PAN work now in EPSG31467 without any problems!
And the "long path" problem was my own fault, simply missing data was the reason ..., so I can confirm now that the qgis-mapserver works also with long path/file names.
Thanks again for the advice.
I am now struggling with the transparency of raster layers, which work on the older Windows QWC but not on the newer QWC on Linux ... but I hope to find the error soon ..
Markus
-----Ursprüngliche Nachricht-----
 Von: "Markus Weidenbach" [landconsult at freenet.de]
 Gesendet: Fr. 27.06.2014 09:50
 An: qgis-user at lists.osgeo.org
 Betreff: Re: [Qgis-user] QWC strange behaviour of Zoom and Pan functions if authid=EPSG31467 and problems with long directory paths in qgis-mapserver
Hi Marco, Bernhard,
 Marco, no I don´t think there is any directory permission problem,       but I will check again ....
 I will also try Bernhard´s proposal to change the settings for the       CRS axis ...
 regards,
 Markus
 Dr. Markus Weidenbach
 landConsult.de
 Geographical Information Management
 and Environmental Planning
 D-77815 Bühl
 Germany
 e.mail see: http://landConsult.deAm 27.06.2014 09:27, schrieb Marco Hugentobler:>Is there a limit of characters         for paths or shapefile names used in the QGIS *.qgs file that         affects the qgis-mapserver?
 Not that I know.
 Is it possible that it is a problem with the file permissions         for the webserver user?
 Regards,
 Marco
 On 27.06.2014 09:08, Markus Weidenbach wrote:Dear List,
 I am running the QGIS Web Client (checkout from GIT HUB on         25.06.14) and QGIS Webserver 2.2.0 on Debian 7.
 In GlobalOptions.js I set the authid variable to 31467 and I am         publishing only data in that projection ( I also disabled Google         Maps in GlobalOptions.js).
 Everything works fine, but the ZOOM and the PAN function in QWC         behave strange, in fact it is almost impossible to zoom or pan         to a selected spot.
 You can test it yourself on
 http://188.138.88141/qgis-web-client/site/qgiswebclient.html?map=/home/wbv/Untersuchungsgebiet_GK3_2.qgs or
 http://188.138.88.141/qgis-web-client/site/qgiswebclient.html?map=/var/www/qgis-web-client/projects/test_GK3.qgs
 Any idea whats wrong here?
 If I switch the QWC back to EPSG3857 the ZOOM/PAN works           normal.
 Another problem I encountered is the fact, that the webserver           is not reading shapefiles which use a very long directory           path.
 e.g. the shape           /var/www/qgis-web-client/projects/wbv/wbv-geodaten/shape/ugebiet/teilgebiet_nord_1km_kacheln.shp             is not listet in the GetCapabilities request (see http://188.138.88.141/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/var/www/qgis-web-client/projects/Untersuchungsgebiet_GK3.qgs).
 But after copying the same shape to           /home/wbv/wbv-geodaten/nord.shp (together with the corrected           *.qgs) this layer is listet in the GetCapabilities request           (see
 http://188.138.88.141/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/home/wbv/Untersuchungsgebiet_GK3_2.qgs)
 and is also displayed in the QWC (see
 http://188.138.88.141/qgis-web-client/site/qgiswebclient.html?map=/home/wbv/Untersuchungsgebiet_GK3_2.qgs).
 Thanks for your comments.
 Markus
 landConsult.de
 D-77815 Bühl
 Germany
_______________________________________________Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
-- Dr. Marco HugentoblerSourcepole -  Linux & Open Source SolutionsWeberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.chTechnical Advisor QGIS Project Steering Committee
-----Ursprüngliche Nachricht Ende-----
Alle Postfächer an einem Ort. Jetzt wechseln und E-Mail-Adresse mitnehmen! Rundum glücklich mit freenetMail
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140627/ff99117e/attachment.html>
