[Qgis-user] Time manager 1.1 in QGIS 2.4
G. Garibaldi
digitalmaps at cox.net
Sun Jun 29 09:36:25 PDT 2014
Yeee Haaaa! Yea boy, we all happy now!
> PostGIS layers should work again
> https://github.com/anitagraser/TimeManager/commit/2d7b769d8937a405c105041f307619c9c58ed62e
> Try http://plugins.qgis.org/plugins/timemanager/version/1.1.2/
> Thanks for reporting this issue!
> On Sun, Jun 29, 2014 at 5:28 PM, Anita Graser <anitagraser at gmx.at> wrote:
>> Thanks. I can now reproduce the issue. It was caused by one of the
>> latest changes to fix DATE type support
>> https://github.com/anitagraser/TimeManager/commit/926fa544bb6a993c41f4dcfc532fa2568c883949
>> Best wishes,
>> Anita
>> On Sun, Jun 29, 2014 at 4:10 PM, G. Garibaldi <digitalmaps at cox.net> wrote:
>>> Same non-functional result on OSGeo4W installer. TM animation works properly
>>> with shape file data. Looks like the problem is with the PostgreSQL database
>>> connection. Permissions would be my guess.
>>> I'll have to export all my point data to shape files to do animation. Hey,
>>> its free.
>>> The QGIS 2.4 release is fast.
>>> Thanks Anita, everybody.
>>> G.
>>> Windows 7 64-bit. QGIS standalone installer. Time Manager version 1.1. I
>>> start a new project, load one vector layer of a PostgreSQL database table
>>> with point data. PostgreSQL version 9.3, PostGIS version 2.1. The data shows
>>> on screen. Open TM dialog and select the layer as usual. Up to this point
>>> everything functions as expected. The screen looks normal. When I enable TM
>>> the data disappears. I check the time, looks OK. Time interval is correct.
>>> Opening the attribute table while TM is enabled shows no datapoints when I
>>> expect one data point. When I disable TM all the data reappears.
>>> Using TM 1.0 enables me to load layers that do function normally, however
>>> when I save the project, exit and then restart the project only one layer
>>> shows in the layer list in TM. The other layers don't get saved.
>>> This is an old project that works well enough in QGIS 1.8. with TM 0.7. In
>>> later versions I can't get TM to function properly.
>>> I'll try the OSGeo4W installer.
>>> Hi,
>>> I get the same deprecation warning but it does not affect the
>>> functioning of the plugin for me with 2.4 installed using OSGeo4W
>>> 64bit installer on Win8.
>>> Could you describe a bit more what happens? Is the whole screen blank?
>>> Or is just the TimeManager panel blank? Which OS?
>>> Best wishes,
>>> Anita
>>> On Sun, Jun 29, 2014 at 8:22 AM, G. Garibaldi <digitalmaps at cox.net> wrote:
>>> I can't get TM 1.1 to work in 2.4 64-bit. Load one layer and it doesn't show
>>> anything when TM is enabled - blank screen. Interestingly, TM 1.0 works
>>> somewhat.
>>> Log File:
>>> warning:C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py:844:
>>> PendingDeprecationWarning: This method will be removed in future versions.
>>> Use 'elem.iter()' or 'list(elem.iter())' instead.
>>> for include in elem.getiterator("include"):
>>> traceback: File "<string>", line 1, in <module>
>>> File "C:/PROGRA~1/QGISCH~1/apps/qgis/./python\qgis\utils.py", line 213, in
>>> startPlugin
>>> plugins[packageName].initGui()
>>> File
>>> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanager.py", line
>>> 44, in initGui
>>> control.initGui()
>>> File
>>> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanagercontrol.py",
>>> line 65, in initGui
>>> self.guiControl =
>>> TimeManagerGuiControl(self.iface,self.timeLayerManager)
>>> File
>>> "C:/Users/Garibaldi/.qgis2/python/plugins\timemanager\timemanagerguicontrol.py",
>>> line 54, in __init__
>>> self.dock = uic.loadUi( os.path.join( path, "dockwidget2.ui" ) )
>>> File
>>> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\__init__.py",
>>> line 238, in loadUi
>>> return DynamicUILoader(package).loadUi(uifile, baseinstance,
>>> resource_suffix)
>>> File
>>> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\Loader\loader.py",
>>> line 71, in loadUi
>>> return self.parse(filename, resource_suffix, basedir)
>>> File
>>> "C:\PROGRA~1\QGISCH~1\apps\Python27\lib\site-packages\PyQt4\uic\uiparser.py",
>>> line 933, in parse
>>> actor(elem)
>>> File
>>> line 844, in readResources
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140629/964d97d3/attachment.html>
