[Qgis-user] Georeferencer problem with Qgis 2.2
Matt Boyd mattslists at gmail.com
Mon Mar 3 19:01:49 PST 2014
I'll chip in as well and say I got this when I ran the georeferencer today.
Same install as above.
On Mon, Mar 3, 2014 at 11:47 PM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Yep, I'm getting this as well. Exact same behaviour.
> QGIS 64-bit, Windows 7.
> Is there a ticket for this?
> Cheers,
> Jonathan
> On 22 February 2014 19:19, Gerardo Jiménez <gejst5 at gmail.com> wrote:
>> Hi
>> I just want to know if somebody else has the sma problem as me. I
>> installed Qgis 2.2 64bits via OSGeo. When I try to use the georefencer, the
>> main window appears, then stops responding, then I have a message saying
>> "bad allocation" and then start responding. After that I can work with the
>> georeferencer without a problem. I have the sam problem in 4 differen
>> machines, all running win 7 64bits.
>> Thanks before hand
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140304/b04ed92e/attachment.html>
