[Qgis-user] QGIS - gdal
Paulo van Breugel p.vanbreugel at gmail.com
Tue Mar 4 00:02:38 PST 2014
I was the one reporting that issue :-).. The problem there was that
qgis did not start. With the solution provided by that link, qgis
starts without problems. It does not help however with the gdal
functions not working, at least, not for me.
On Tue 04 Mar 2014 08:54:37 AM CET, Alex Mandel wrote:
> I suspect its an ld path configuration issue. Similar to this but with GDAL
> http://hub.qgis.org/issues/5859
> Thanks,
> Alex
> On 03/03/2014 11:50 PM, Paulo van Breugel wrote:
>> Hi Matt,
>> Yes I did, no luck. I now also installed QGIS and gdal using the
>> ubuntugis ppa, and that works. But I still would like to get this to
>> work to be able to use/test the QGIS development version.
>> Paulo
>> On Tue 04 Mar 2014 04:08:30 AM CET, Matt Boyd wrote:
>>> Hi Paulo,
>>> I'm a little out of practice configuring gdal in linux, but I vaguely
>>> recall doing something like this a while ago, my apologies if this is
>>> a too obvious.
>>> Have you looked at the gdal tool settings in the raster menu of qgis?
>>> Matt
>>> On Mon, Mar 3, 2014 at 9:41 PM, Paulo van Breugel
>>> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>>>      Hi I am running QGIS master on Ubuntu 13.10. All runs fine, except
>>>      for any function  that relies on gdal (raster menu or the gdal
>>>      functions in the processing toolbox). The functions work without
>>>      problem on the command line, but QGIS cannot find gdal it seems.
>>>      I compiled QGIS with the following gdal settings:
>>>        * GDAL_CONFIG = /usr/local/gdal1.10/bin/gdal-config
>>>        * GDAL_CONFIG_PREFER_FWTOOLS_PATH = /bin_safe
>>>        * GDAL_CONFIG_PREFER_PATH = /bin
>>>        * GDAL_INCLUDE_DIR = /usr/local/gdal1.10/include
>>>        * GDAL_LIBRARY = /usr/local/gdal1.10/lib/libgdal.so
>>>      I am actually not sure about the 2nd and 3rd.  Are those settings
>>>      correct?
>>>      I compiled gdal 1.10 from source in /usr/local/gdal and tried all
>>>      the following:
>>>        * added a gdal.conf file with the gdal lib path in the
>>>          etc/ld.so.conf.d folder (ran ldconfig)
>>>        * created a softlink of the usr/local/gdal1.10/bin folder in
>>>          /usr/bin
>>>        * defined gdal paths in /home/paulo/.bashrc by adding the line:
>>>          export PATH=$PATH:/usr/local/gdal1.10/bin
>>>        * created executable file libraries.sh in /etc/profile.d with
>>>          the lines
>>>            o #!/bin/sh
>>>            o
>>> LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/lib:/usr/local/lib:/usr/local/gdal1.10/lib"
>>>            o export LD_LIBRARY_PATH
>>>      Any idea what to do next?
>>>      Paulo
>>>      _______________________________________________
>>>      Qgis-user mailing list
>>>      Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>      http://lists.osgeo.org/mailman/listinfo/qgis-user
