[Qgis-user] Very simple webgis in just one single svg file
Carlos Cerdán sig.upagu at gmail.com
Wed Mar 5 05:44:10 PST 2014
+1
In efect, that plugin would be very nice.
Something to consider about SVG maps is that letters must be changed to
"lines?" (it says "trayectos" in Spanish) in order to see it in an internet
navigator. I do it using Inkscape.
All the best
Carlos
2014-03-05 4:48 GMT-05:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 05/03/2014 10:44, magerlin ha scritto:
> > A plugin would be VERY nice but I have no knowledge on writing plugins.
> > I will be happy if anyone else can make it!
> Please extend this discussion to qgis-dev: if you are lucky there may be
> someone able to help you.
> > Would the workflow using a plugin be that the user "on his own" creates
> the
> > Map.svg and eventually a separate Legend.svg file and the runs the plugin
> > supplying it with the file names for the created svg files?
> > Or could it somehow be integrated in the print composer for instance as
> an
> > option when exporting as SVG or as a parallel to creating an atlas?
> I would see it as a separate function, similar to the html map plugin
> currently available: a new entry "create your web map" that creates the
> three necessary files (and perhaps displays them in a webkit window).
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140305/36ee4f41/attachment.html>
