[Qgis-user] QGis 2.0.1 (german version): Transect with square polygons
Alexandre Neto
senhor.neto at gmail.com
Wed Mar 5 08:48:04 PST 2014
If you still would prefer do it manually, please take a look into Improved
Polygon Capturing plugin.
Alexandre Neto
On Wed, Mar 5, 2014 at 4:43 PM, Alexandre Neto <senhor.neto at gmail.com>wrote:
> On Tue, Mar 4, 2014 at 2:48 PM, Daniel88 <d.weinberg at posteo.de> wrote:
>> So far I know only the corresponding functions in ArcMap from ESRI. QGis
>> seems equipped in the basic version with less features.
> If you look carefully you see that qgis has many features that in ArcGIS
> are only available in (very well) payed extentions. You just need to know
> where to find them.
>> Although I have the
>> plugin " Rectangles ovals digitizing " installed, but can not choose here
>> the edge length . In addition, the following square is to connect
>> seamlessly
> For me, the fastest way to do this would be to use Andreas suggestion, the
> Vector Grid, to create the the necessary number of squares (Polygons), say
> 18 x 2.
> Like Andre said, they will be aligned with the coordinate system and not
> with your working area. But that is not a problem, cause you can edit the
> layer, select the desired squares, and use Rotate feature and move feature
> in the digitizing toolbar to align and put the squares over your working
> area.
> Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140305/35eeca93/attachment.html>
