[Qgis-user] trouble adding non-spatial table
Alexandre Neto senhor.neto at gmail.com
Wed Mar 5 14:53:39 PST 2014
Have you tried the add delimited text function? You can set lots of options
there to make sure that your data is read properly.
Alexandre Neto
Em 05/03/2014 22:06, "Katie Bradley" <kbradley at ucdavis.edu> escreveu:
> Hi,
> I'm pretty new to QGIS and could use some help with a challenge, if that's
> appropriate to ask on this e-mail list.
> I have a shapefile of California counties. And, I want to add a
> non-spatial table that I can join with the shape file. The table is saved
> as a .csv and I made a .csvt to go with it. When I try to add the .csv as a
> vector layer, I get an error message that the file path is "not a valid or
> recognized data source." I made sure that there are no special characters
> or spaces in the file names, paths, and column headers. Can anyone explain
> the conditions that need to exist for it to be a valid or recognized data
> source? I'm using  QGIS 2.0.1-Dufour, if that matters.
> Thanks,
> Katie
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140305/206b37b7/attachment.html>
