[Qgis-user] complete a polygon
Randal Hale
rjhale at northrivergeographic.com
Thu Mar 6 04:29:07 PST 2014
Tata,
You are referring to a tool that is comparable to autocomplete in the
ESRI world. The closest I have gotten is the autotrace plugin (and it's
not comparable - but it's closer to what you are looking for -
http://www.lutraconsulting.co.uk/resources/autotrace). As for a process
- the best (as far as I know and I hope I am wrong) is to digitize your
work area as polylines - at the end convert them to polygons (vector ->
geometry tools -> lines to polygons). It would save some clicking but
would add a step (or maybe two).
Anyway - Good luck!
Randy
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
http://about.me/rjhale
On 03/06/2014 07:05 AM, Blumentrath, Stefan wrote:
> Avoid Intersection is under "Settings" à"Snapping options".
> If that is checked for your layer you can simply continue digitizing
> with the "create polygon" tool...
> Cheers
> Stefan
> *From:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf Of *SIT delle
> Riserve Naturali di Legambiente Sicilia
> *Sent:* 6. mars 2014 12:30
> *To:* Saber Razmjooei
> *Cc:* qgis-user
> *Subject:* Re: [Qgis-user] complete a polygon
> Dear Saber, thank you!
> But this tools allows me to complete a polygon "inside" another.
> I'm searching for a tool that alow me to complete a polygon outside
> another, that has common sides
> If I have polygon 1 and 2, andI wan to to digitize polygon 3, I'm
> searching a tool that allow me to digitize pol 3 without redraw the
> common sides with 1 and 2 (in thi case ise very simple redraw,, but
> with complex and natural polygons it is an heavy WORK!!)
> Thank you.
> Tata
> Il 06/03/2014 11:14, Saber Razmjooei ha scritto:
> If I have understood your question correctly, you can use AutoTrace plugin.
> See more details here:
> Cheers
> Saber
> On 6 Mar 2014 10:05, SIT delle Riserve Naturali di Legambiente Sicilia<sit at legambienteriserve.it> <mailto:sit at legambienteriserve.it> wrote:
> Hi,
> I have to add a new polygon to other existing; they have obviously
> common sides; how can I draw only sides not common?
> Thank you
> Tata Livreri
> Legambiente Comitato Regionale Siciliano
> Ufficio Gestione Riserve
> Sistema Informativo Territoriale
> tel 0916262697 - 0906264139
> www.legambienteriserve.it <http://www.legambienteriserve.it>
> via Tripoli 3 - Palermo 90138
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140306/f9111e74/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140306/f9111e74/attachment.jpe>
