[Qgis-user] Missing SVG's - now represented by a ? - ?
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Mar 7 09:42:43 PST 2014
Hi List,
I have a QML file I created some time ago. When I open it in QGIS now it
can't find the SVG files - that's fine, it's because they're not there.
My problem is that rather than not rendering the icons, what QGIS now
appears to be doing is instead rendering little "?" icons. I can't figure
out how this is desirable (well, unless you're the Riddler I guess).
Previously in this circumstance QGIS simply didn't render the missing
SVG's, which was fine. But now I have a very unprofessional looking map
style.
I am aware I can update my QML to remove the SVG's, however it's quite
large and I'd rather not have to.
So my question for the list - am I the only person who preferred the old
behaviour?
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140307/25f333fc/attachment.html>
