[Qgis-user] Relationships and SQL Spatial as Child
Alex Mandel tech_dev at wildintellect.com
Fri Mar 7 11:16:26 PST 2014
Sounds like a bug, I suspect that your db combo is more rare and not
many people have tried it yet.
Ask on the developer list or file a ticket on hub.qgis.org
thanks,
Alex
On 03/07/2014 07:24 AM, James Wood wrote:
> Just wanted to float this one again to see if anyone had any feedback.
> Thanks,
> ---------- Forwarded message ----------
> From: James Wood <jwood911 at gmail.com>
> Date: Sun, Mar 2, 2014 at 10:43 AM
> Subject: Relationships and SQL Spatial as Child
> To: QGIS-User Mailing List <qgis-user at lists.osgeo.org>
> Hello QGIS Users,
> Just wanted to know if anyone else has run into this...
> I'm running QGIS 2.2 x64 (OSGeo4W installer) on Windows 7 SP1.
> When trying to utilize the new Relations piece (which is a GREAT addition),
> I can establish relationships and have them work perfectly except when the
> child (or referencing layer) is in my SQL Express 2012 database. I set up a
> test project with identical address points and parcel layers in PostGIS,
> SpatiaLite and SQL. I can get any combination to work, but when the child
> layer is in the SQL db it will not.
> A picture is worth a thousand words, so I took some screenshots:
> I've double-checked the linking ID field for the parcels and it is always a
> 1:1 with the address point I have identified. However, just to be sure it
> wasn't something funky with the parcel base, I established a link between
> the address points and an aed (defibrillator) point layer that I had with
> the same result. I also tried establishing a relationship with a
> non-geometry table in another db in the same instance without any luck.
> I'll be interested in your feedback...
> Thanks,
> James
> Qgis-user mailing list
