[Qgis-user] Can't get qGIS server running under Windows 8.1
Leandro Sastre Salim leandrosastre at gmail.com
Sat Mar 8 05:11:05 PST 2014
UPDATE:
I've used a very simple qGIS project (i.e. withouth raster images) in order
to test the server and worked fine. Are there any tricks in order to make
it work with a more complex project?
Thanks all and sorry for the inconvenience.
Cheers
Leandro.
On 8 March 2014 09:28, Leandro Sastre Salim <leandrosastre at gmail.com> wrote:
> Hi All,
> I've been trying to set up a qGIS web server following these instructions:
> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial#Windows
> Instalation of Apache Webserver and QGIS Server worked smoothly using OsGeo4W-Installer,
> and afer following the configuration steps described in the guide linked
> above I can successfully see that apache is running in
>  http://localhost/
> There is currently 1 osgeo4w application installed.
>> PHP 5.2.5:
>> phpinfo <http://localhost/phpinfo.php>
> However, when I try to load a project, or even test the capabilities of
> the server I get an error. Executing the file in command line returned the
> following:
> C:\OSGeo4W\apps\qgis\bin>qgis_mapserv.fcgi.exe
>> Qt: Untested Windows version 6.2 detected!
>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
>> variable.
>> variable.
>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>> environment variable.
>> variable.
>> Content-Type: text/xml
>> Content-Length: 217
>> <ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc
>>  <ServiceException code="OperationNotSupported">Please check the value of
>> the RE
>> QUEST parameter</ServiceException>
>> </ServiceExceptionReport>
> Not sure what to do now, I've searched online and in the mailing list and
> couldn't find the answer.
> I'm running QGIS 2.2.0.
> Thanks in advance,
> Best Regards.
> Leandro.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140308/132bd6b6/attachment.html>
