[Qgis-user] QGIs crashes opening old (2.0.1) projects in valmiera (2.2.1)
Víctor Manuel Herreros Villanueva
vherreros at ucm.es
Thu Mar 13 05:27:26 PDT 2014
Alexander,
I've tried to open it under QGIS Valmiera, Windows 7 64 bit.
I've had to click 'Cancel' for all of your layers database connections
(cause I don't have your tables in my PostgreSQL Server) - patiently
waiting more or less 30 seconds until my server time outs for each of your
22 tables.
Then I got a 'missing file' error in QGIS (cause I don't have
'//Fileserver/PRIVATE/Ortos/ORTOS2013/ortos2013.vrt' file on my
filesystem). QGIS told me this layer would be lost, and I agreed.
The I got a minidump, whose contents are inside the file uploaded
here<http://www.mediafire.com/download/51qjs8257a63n6n/qgis-20140313-131106-4984-2232-c3a2817.dmp>,
in case you want it for opening the ticket.
And finally, QGIS closed.
So I've not been able to open it.
Sorry...
2014-03-13 12:52 GMT+01:00 Alexandre Neto <senhor.neto at gmail.com>:
> Hello Ariel,
> Even in new installations the project fails to open and crashes.
> As a workaround, I was able to open a new blank project, and add all layer
> groups using embed
> layer and groups... and recreate part of the project, But all print
> composers are lost, and probably other stuff that I'm not aware of now.
> I think I will open a ticket for this, and do some more testings.
> Thanks for your answer,
> Alexandre
> On Thu, Mar 13, 2014 at 8:21 AM, Rodriguez, A. <arielrod24 at gmail.com>wrote:
>> Alexander:
>> Try to uninstall and re-install the software.
>> Greetings and good luck.
>> Ariel
>> On 12/03/14 17:27, Alexandre Neto wrote:
>> Hello,
>> I'm having problems opening a Dufour project (2.0.1) in Valmiera (2.2.1)
>> using windows 7 64 bit.
>> QGIS warns me that a older version project is going to be opened, but
>> crashes during the reading of the layers. The same file still opens in
>> 2.0.1 without problems.
>> Is there any known issues of lower versions compatibility? Any
>> workarounds?
>> The problematic project is the following:
>> https://dl.dropboxusercontent.com/u/110618644/SIG_DTOP.qgs
>> Thanks,
>> Alexandre Neto
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
<http://www.ucm.es/> *Universidad Complutense de
Madrid*<http://www.ucm.es/> *Víctor
Manuel Herreros Villanueva*, PhD.
Project Manager
*Facilities ManagementData Warehouse*
Jardín Botánico
Av. Complutense s/n
28040 Madrid
Spain
*Phn. no. (+34) 91 394 7275Fax no. (+34) 91 394 4773* vherreros at ucm.es
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140313/619cbc1c/attachment.html>
