[Qgis-user] Batch contour extract
Leandro Girardin leandrogirardin at yahoo.com.ar
Thu Mar 13 09:52:32 PDT 2014
Dear Maning, the solution you proposed was evan better than I imagined it could be done. Thank you very much.
Greets,
Leandro.
 De: maning sambale <emmanuel.sambale at gmail.com>
Para: Leandro Girardin <leandrogirardin at yahoo.com.ar>
CC: qgis-user <qgis-user at lists.osgeo.org>
Enviado: jueves, 13 de marzo de 2014 3:35
Asunto: Re: [Qgis-user] Batch contour extract
Dear Leandro,
Two steps I do:
1. Create a vrt of all the DEM files (gdalbuildvrt).
2. Extract contour from the VRT file (gdal_contour).
Both tools are available in the Raster menu.
You can also script this and run the process for each DEM file but you
will have separate contour layers that stops at the edge of your DEM
tile.  I want to avoid this which I why I use the VRT file.
A CLI version of this process I posted here:
http://epsg4253.wordpress.com/2013/02/08/building-contour-elevation-lines-with-gdal-and-postgis/
On Wed, Mar 12, 2014 at 10:13 PM, Leandro Girardin
<leandrogirardin at yahoo.com.ar> wrote:
> Hello. I need to perform a contorur extract of 41 raster hgt files, all with
> the same configuration. Is there any way of doing this automatically? Thank
> you in advance. Leandro.
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140313/417ddac5/attachment.html>
