[Qgis-user] QGIS Web Client for Windows 7
Bernhard Ströbl bernhard.stroebl at jena.de
Thu Mar 13 23:48:45 PDT 2014
Hi Markus,
I cannot access any of the URLs you provided, are they supposed to be
accessed from the internet?
If you want to use your demo project you have to set the projection in
GlobalOptions.js to the projection of your data and project (i.e.
EPSG:31467). Therefore you need to define this projection as projection
file in site/js/libs/proj4js/defs I just added EPSG:31468 to QWC for you
to see how to do it. So checkout the latest version first.
You also have to set yx in LayerOptions to true for EPSG:31467.
Hope that helps
Bernhard
Am 13.03.2014 21:07, schrieb Markus Weidenbach:
> Hi Bernhard,
> thanks for your comments.
> The helloworld.qgis is being provided within the QGIS Web Client Master
> version as a default *.qgs stored in
> C:\OSGeo4W\apache\htdocs\QGIS-Web-Client-master\projects , so that`s why
> I think it should work.
> Now I found that it is not even working as a simple QGIS Server WMS
> Request, as follows:
> http://landconsult.no-ip.com/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:3857&REQUEST=GetMap&map=C:\OSGeo4W\apache\htdocs\QGIS-Web-Client-master\projects\helloworld.qgs&BBOX=-25749149,-13032966,26101391,21121731&WIDTH=1000&HEIGHT=800&LAYERS=Hello,Country&FORMAT=image/png
> Instead my own qgis project "wms_demo.qgs" with two shape files works
> fine with the QGIS Server but it does not work with the Web Client ...
> This works fine:
> http://landconsult.no-ip.com/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:31467&REQUEST=GetMap&map=C:\OSGeo4W\apache\htdocs\QGIS-Web-Client-master\projects\wms_demo.qgs&BBOX=3453493.9,5358354.8,3461626.4,5363507.8&WIDTH=1000&HEIGHT=800&LAYERS=weg,bach&FORMAT=image/png
> it also works without the SRS/EPSG information:
> http://landconsult.no-ip.com/qgis/qgis_mapserv.fcgi.exe?REQUEST=GetMap&map=C:\OSGeo4W\apache\htdocs\QGIS-Web-Client-master\projects\wms_demo.qgs&BBOX=3453493.9,5358354.8,3461626.4,5363507.8&WIDTH=1000&HEIGHT=800&LAYERS=weg,bach&FORMAT=image/png
> But this one does not work (WebClient Interface is o.k., but shapes are
> not loading):
> http://landconsult.no-ip.com/QGIS-Web-Client-master/site/qgiswebclient.html?map=../projects/wms_demo.qgs
> I am afraid the reason might be a simple path setting in the
> C:\OSGeo4W\apache\htdocs\QGIS-Web-Client-master\site\js files ....
> that´s why it would be helpful to know somebody with a working QWC on
> Windows.
> Regards,
> Markus
> Dr. Markus Weidenbach
> *landConsult.de*
> Geographical Information Management
> and Environmental Planning
> D-77815 Bühl
> Germany
> e.mail see: http://landConsult.de
> Am 13.03.2014 12:10, schrieb Bernhard Ströbl:
>> Hi Markus,
>> I have no experience with QWC and Windows but maybe if you describe
>> what you have done and what happens you may get an answer from the
>> list. Your URLs are not accessible (time-out), at least for me.
>> More comments below
>> Am 13.03.2014 10:37, schrieb Markus Weidenbach:
>>> Dear List,
>>> for 2 days I was trying to get the QGIS Web Client running on my Windows
>>> 7 / Apache 2 system.
>>> I think I checked almost all comments and (still left open) questions on
>>> that issue on the web and this mailing list and my impression is, that
>>> nobody ever successfully installed the QGIS Web Client on Windows/Apache
>>> or am I wrong (?).
>>> So, before I change to 3Liz lizmap-web-client, this post is my last hope
>>> to get a positive answer ....
>>> My settings are:
>>> - Windows 7, 64 bit with QGIS 2.2 and _fully working QGIS Server_ on
>>> Windows/Apache (all updated/loaded on 10. March 2014 from OSGEO4W setup,
>>> QGIS Server and Apache loaded with OSGEO4W "Web GIS Fast Installation"
>>> setup mode).
>>> - QGIS Web Client downloaded ZIP from
>>> https://github.com/qgis/QGIS-Web-Client on 10. march 2014
>>> Like many other users I could successfully install the QGIS Server and
>>> display my *.qgs data as a map on the browser and also get the
>>> GetCapabilities information etc.
>>> If you find my server switched on you can check:
>>> http://landconsult.no-ip.com/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:31467&REQUEST=GetMap&map=C:/OSGeo4W/apps/qgis/bin/wms_demo.qgs&BBOX=3453493.9,5358354.8,3461626.4,5363507.8&WIDTH=1000&HEIGHT=800&LAYERS=weg,bach&FORMAT=image/png
>> this is not Hello World, is it?
>>> But after the setting-up of the QGIS Web Client files under
>>> C:\OSGeo4W\apache\htdocs\QGIS-Web-Client-master and after adjusting all
>>> possible paths (including the right path in the GlobalOptions.js file at
>>> <<var serverAndCGI = "http://127.0.0.1/qgis/qgis_mapserv.fcgi.exe">> I
>>> was only able to see the QGIS Web Client interface but unfortunately not
>>> the default map "helloworld.qgs".
>>> http://landconsult.no-ip.com/QGIS-Web-Client-master/site/qgiswebclient.html?map=/Qgis-Web-Client-master/projects/helloworld.qgs
>> so do you get Hello world in another client (entering a GetMap request
>> in your Browser or QGIS desktop)?
>> Why are you not setting QWC on the project you mention above in order
>> to decide whether it is a server or client problem?
>>> So after all the reading and testing, I am not sure if QGIS WebClient is
>>> able to run on Windows/Apache at all?
>>> Is there anybody out there with a working QGIS Web Client on
>>> Windows/Apache?
>>> Thanks for your answers in advance (even if it is "no").
>>> Regards,
>>> Markus
>> Bernhard
>> __________ Information from ESET Security, version of virus signature
>> database 9536 (20140313) __________
>> The message was checked by ESET Security.
>>    part000.txt - is OK
>> http://www.eset.com
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> database 9539 (20140313) __________
> - is OK
>  > MIME > part000.txt - is OK
>  > MIME > part001.htm - is OK
> part001.txt - is OK
> http://www.eset.com
> __________ Information from ESET Security, version of virus signature database 9539 (20140313) __________
>       - is OK
>      part001.txt - is OK
> http://www.eset.com
__________ Information from ESET Security, version of virus signature database 9540 (20140313) __________
    part000.txt - is OK
http://www.eset.com
