[Qgis-user] How to represent Water Bore/Borewells in 3D view using qgis..?
josef k groundwatergis at gmail.com
Mon Mar 17 07:08:28 PDT 2014
Andreas,
I already included a small fix to make the top surface being visible from
below. Have close look here: http://goo.gl/8pDR4o (Or maybe I
misunderstood, was it something else that you had in mind?)
Unfortunately I do not know how to interact with the objects, but I do
agree - that would be a great enhancement.
/Josef
Date: Mon Mar 17 05:22:38 PDT 2014
> From: Andreas Neumann <a.neumann at carto.net>
> Nice!
> I wonder if we could do something so that the top surface can be seen
> from below? Currently, if you look from below it is just fully
> transparent - not so optimal in this case.
> The other thing that would be very nice if you could interact with these
> objects - click on a borehole and get the attribute data. Is it
> technically to add events to objects?
> Andreas
> Am 17.03.2014 12:01, schrieb josef k:
> * Carlos, *>
> * I just made a pull request for Qgis2threejs to enable the use of
> multiple *>
> * DEMs to illustrate geological layers: http://goo.gl/rVUwmn
> <http://goo.gl/rVUwmn> *>
> * I do not know about your usage but for me this is revolutionary in the
> FOSS *>
> * world. *>
> * (I considered using wireframes for the subsurface layers but ended up
> not *>
> * doing so, although it was not an obvious decision: http://goo.gl/vWN3kr
> <http://goo.gl/vWN3kr>) *>* /Josef*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140317/afdec8b2/attachment.html>
