[Qgis-user] Well Symbols
Joachim Józefowicz joachimjozefowicz at gmail.com
Wed Mar 19 07:37:49 PDT 2014
Hi Ross
You must save those symbols like png file. Next convert to svg file. You
can do this with this converter:
http://image.online-convert.com/convert-to-svg
Next put your svg symbols in this path C:\OSGeo4W\apps\qgis\svg
also You can create a new folder on this path.
------ Wiadomość oryginalna ------
Od: "Ross Easterling" <rosseast2004 at yahoo.com>
Do: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Wysłano: 2014-03-19 15:08:21
Temat: [Qgis-user] Well Symbols
>This is my first post to your list.  Hello!
>How can I add oil and gas well symbols to a map?  An example of what I
>am looking for is at:
>http://igs.indiana.edu/pdms/Help/Petroleum_Well_Symbols.htm
>ESRI has a symbol set, I think it is called:    esri: oil, gas, water
>Are symbols in QGIS like a font?
>I've been looking for something I could download and use in a vector
>layer.  And, If I could get my hands on such a symbol set what would I
>do with it? I mean, how would I install it? Does it go in a directory
>with qgis?   How would I make it an option that I could choose (in
>properties, labels, styles) if I had it? In other words, where would it
>live.  Would it be available in every new project I create in QGIS or
>would I need to add it in.
>I've downloaded County oil and gas wells from the Texas Railroad
>Commission and QGIS shows a dot like a bullet point. I'm thinking that
>those shapefiles would pull
>I'm really enjoying QGIS!
>R
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140319/536b7797/attachment.html>
