[Qgis-user] Missing labels in polygons
Larry Shaffer larrys at dakotacarto.com
Wed Mar 19 12:42:24 PDT 2014
Hi David,
On Wed, Mar 19, 2014 at 1:33 PM, Chrest, David <davidc at rti.org> wrote:
> This is in QGIS 2.2. When I label a polygon layer, in my case a very
> simple shapefile of just a few sates, only 2 of the 8 labels appear and the
> rest are missing. When I go into edit layer mode, I see all labels, then
> turn off edit mode, and only the same two labels appear. When I zoom so far
> out that my group of U.S. states are nothing but a dot, the rest of the
> labels appear. Very strange. I see that this is some kind of logged bug
> with the new label engine, correct? Is there some kind of fix planned since
> this pretty much causes the inability to label polygons?
Try turning off "Simplify geometry" for the layer.
See (should be fixed in master):
http://hub.qgis.org/issues/9655
http://hub.qgis.org/issues/9673
Please do not cross-post to multiple mailing lists, i.e. to QGIS User and
Dev, unless absolutely necessary.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
> Thanks for any help that can be provided.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140319/98c4950a/attachment.html>
