[Qgis-user] Polygon shapefile not visible if overlapping another shapefile
Lene Fischer lfi at ign.ku.dk
Thu Mar 20 00:17:06 PDT 2014
Hi Christine,
There are several possibillities:
But if your settings are set to Avoid intersection, you polygon will be "clipped" against existing polygons. If you digitize entire over a polygon - it will be clipped away entirely.
So please check in: Setting>Snapping and remove Avoid intersection.
Regards
Lene Fischer
Associate Professor
Department of Geosciences and Natural Resource Management
University of Copenhagen
MOB +45 40115084
lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>
[SCIENCE_bomaerke_UK]
Fra: qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Christine Griffiths
Sendt: 20. marts 2014 05:51
Til: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Emne: [Qgis-user] Polygon shapefile not visible if overlapping another shapefile
Dear All,
Any help would be much appreciated as I am starting to go insane!
Every time I draw a polygon shapefile in qgis 2.2 it will only shows up if it does not overlap another shapefile. I cannot fathom why it is not visible. I never had this problem in QGIS 1.8. This new shapefile is at the top of my table of contents.
Thanks
Christine
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Christine Griffiths
Dear All,
Thanks
Christine
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140320/e096bb99/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140320/e096bb99/attachment.jpg>
