[Qgis-user] Problem installing on Mac Mavericks
William Kyngesburye woklist at kyngchaos.com
Tue Mar 25 11:57:08 PDT 2014
When did you download GDAL Complete and where from?  You probably had an old link.  GDAL Complete from my site has a version in the name, so there should be no confusion.  Both 1.10 and 1.9 are available, so make sure you get the right one.
On Mar 25, 2014, at 1:13 PM, David Mladenoff <djmladen at wisc.edu> wrote:
> Ah, yes but it is 1.9.  I thought it was 1.1 if you install GDAL Complete. Do you know what I did wrong?
> On 3/25/14, 9:19 AM, William Kyngesburye wrote:
>> That's very strange.  Do you have this file on your HD:
>> /Library/Frameworks/GDAL.framework/Versions/1.10/Resources/Info.plist
>> What is the exact message?  (there are 2 tests for GDAL, with different messages)
>> On Mar 25, 2014, at 9:04 AM, David Mladenoff <djmladen at wisc.edu> wrote:
>>> Yes, that's right.  And it it QGIS 2.2.
>>> On 3/20/14, 7:19 PM, William Kyngesburye wrote:
>>>> I assume you mean GDAL Complete 1.10?
>>>> Which version of QGIS?
>>>> On Mar 20, 2014, at 2:45 PM, David Mladenoff <djmladen at wisc.edu> wrote:
>>>>> I am having a problem installing QGIS on a new Mac Mini with Mavericks.  I installed the compete GDAL, but when I click to install QGIS, I get an error message saying it needs GDAL 1.1; included in GDAL complete.
>>>>> I did a second successful install of GDAL, but get the same message when trying to install QGIS.
>>>>> Has anyone seen this problem and have a solution?
>>>>> Thanks.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
