[Qgis-user] Problem opening .GDB (v 10.1) using QGIS
cdp cdaponte at synergyaspen.ca
Thu Mar 27 10:16:36 PDT 2014
so did both of you successfully open the file in QGIS but QGIS did not
present the theme picker?  When I open the file I only receive a red bar
across QGIS which tells me something must also be wrong with my setup.  I
installed the GDAL GBD library in QGIS...are there other libraries that need
to be installed with it?
It seems that there is some sort of bug preventing the theme picker from
opening...?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-opening-GDB-v-10-1-using-QGIS-tp5131380p5131626.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
