[Qgis-user] Atlas generation - Rule based renderer on two different layers??
Pietro Rossin pierigis at gmail.com
Mon Mar 31 03:05:19 PDT 2014
The statement for the label:
CASE WHEN contains($geometry , centroid($atlasgeometry)) THEN my label END
WORKS!
But the two layers must be in the same reference system...
Thanks!
2014-03-28 14:03 GMT+01:00 Pietro Rossin <pierigis at gmail.com>:
> Hello
> If I try to apply a ruled style with this statements I cannot achieve
> expected result
> IE apply a style to feature layer if the centroid of the atlas feature is
> in the feature to be styled
> intersects(centroid($atlasgeometry), $geometry )
> within(centroid($atlasgeometry), $geometry )
> contains($geometry,centroid($atlasgeometry) )
> Where is my mistake?
> bie
> 2014-03-28 10:03 GMT+01:00 Pietro Rossin <pierigis at gmail.com>:
>> Thank you Alexandre
>> Yess!!!
>> I get rid of the problem just after this posting.. And indeed the
>> solution was as written on the end of Nathan post..
>> Now i was playing with label rules but without success...
>> I have two polygon layers, each feature of the first one can perfectly
>> contain one or more features of the second (this last is the layer for the
>> atlas generation), but sometimes the atlas feature can slightly exceed the
>> containing polygon of the first layer
>> I want the label to appear for the first layer only for the feature that
>> contains the atlas feature and not for the surrounding ones...
>> So I wrote this statement:
>> But it doesn't work...
>> 2014-03-28 9:06 GMT+01:00 Alexandre Neto [via OSGeo.org] <[hidden email]<http://user/SendEmail.jtp?type=node&node=5131732&i=0>
>>  Yes you can. check the end of this post.
>>> http://nathanw.net/2013/12/02/waiting-for-qgis-22-highlighting-current-atlas-feature/
>>> Alexandre Neto
>>> Em 28/03/2014 07:56, "Pietro Rossin" <[hidden email]<http://user/SendEmail.jtp?type=node&node=5131715&i=0>>
>>> escreveu:
>>>> Hello people
>>>> I'm using the atlas generator and I'm able to use a rule based renderer
>>>> on
>>>> the Atlas feature showed by the filter: $id = $atlasfeatureid
>>>> I'm wondering if it is possible to render the symbology of a second
>>>> layer
>>>> using a distance criterion
>>>> I know postgis can query a feature layer by distance with a second layer
>>>> with st_dwithin(g1,g2,d).
>>>> Is it possible to make something similar on the fly using the $geometry
>>>> of
>>>> the second layer and $atlasgeometry as the selector by distance of the
>>>> feature to be rendered?
>>>> bie
>>>> pietro
>>>> View this message in context:
>>>> http://osgeo-org.1560.x6.nabble.com/Atlas-generation-Rule-based-renderer-on-two-different-layers-tp5131712.html
>>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5131715&i=1>
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5131715&i=2>
>>>  If you reply to this email, your message will be added to the
>>> discussion below:
>>> http://osgeo-org.1560.x6.nabble.com/Atlas-generation-Rule-based-renderer-on-two-different-layers-tp5131712p5131715.html
>>>  To unsubscribe from Atlas generation - Rule based renderer on two
>>> different layers??, click here.
>>> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: Atlas generation - Rule based renderer
>> on two different layers??<http://osgeo-org.1560.x6.nabble.com/Atlas-generation-Rule-based-renderer-on-two-different-layers-tp5131712p5131732.html>
>> Sent from the Quantum GIS - User mailing list archive<http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140331/e84727b2/attachment.html>
