[Qgis-user] processing upgrade broken
Alex Mandel tech_dev at wildintellect.com
Tue May 6 10:08:42 PDT 2014
I can confirm this is a bug. Happens on Ubuntu also. The default version
installed is not cleanly masked by the upgraded version in the user folder.
Installed version: 2.0 (in /usr/share/qgis/python/plugins/processing)
Available version: 2.2.0-2 (in QGIS Official Plugin Repository)
Attempting to upgrade throws the error mentioned before:
no module named qgis.QGISAlgorithmProvider
Workaround is to remove the version that ships with QGIS. Thats not
really a good solution for most users.
Thanks,
Alex
On 05/05/2014 01:18 PM, G. Allegri wrote:
> Try removing the processing plugin folder and reinstall it.
> Be sure you don't have it also installed under <user>/.qgis2/python/plugins
> Removing and reinstalling worked for me.
> giovanni
> 2014-05-05 20:42 GMT+02:00 Kurt Trinko <ktrinko at gmail.com>:
>> upgraded processing on win 7 64 bit has broken the plugin
>> anyone else with this problem?
>> kurt
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
