[Qgis-user] Text size expression
Larry Shaffer larrys at dakotacarto.com
Mon May 12 19:38:29 PDT 2014
Hi Liam,
Having multiple font sizes per label is not supported yet.
You will have to duplicate the layer, create an expression for the each
row, set each layer's font size accordingly and play with the vertical
offset (or quadrant) to get the desired effect.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Mon, May 12, 2014 at 6:05 PM, Liam Anderson <hokimaps at gmail.com> wrote:
> I would like to make a label with two different text sizes in it( see
> below).  It needs to be one label with an expression using two fields.  Can
> someone give me an expression for defining font size?
> Site: 3
> 12.1 Ha
> Thanks, Liam.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140512/ad419d17/attachment.html>
