[Qgis-user] Help for QGIS-Web-Client
Bernhard Ströbl bernhard.stroebl at jena.de
Tue May 13 06:00:23 PDT 2014
Hi Amandine,
the errors you post are errors because of a previous error.
I cannot debug this from here, sorry, as your server is not publicly
available.
Idea 1: double check, that you have your CRS EPSG:2154 set as CRS for
the project in project properties/"CRS" (NOT only in "OWS server"!)
Idea 2: Was the project saved from the same QGIS version as QGIS server?
Idea 3: Install QWC freshly from the repository, just change the authid
in Global options and see what happens
Bernhard
Am 13.05.2014 10:01, schrieb Amandine SCHLOUPT:
> Hi,
> OK. The value of "var useGetProjectSettings" is true.
> When I change the value by false, all layers are selected.
> But my problem don't change...
> In my previous version of QWC (after updates of apache2, qgis,
> python-qgis, libapache2-mod-fcgid, qgis-mapserver), I have the same
> problem : the map don't load.
> But my error is diferrent :
> "TypeError: y is null" in ext-all.js (line 7)
> Thanks
> *Amandine *
> *De: *"Bernhard Ströbl" <bernhard.stroebl at jena.de>
> *À: *"Amandine SCHLOUPT" <aschloupt at aguram.org>, "Andreas Neumann"
> <a.neumann at carto.net>
> *Cc: *qgis-user at lists.osgeo.org
> *Envoyé: *Mardi 13 Mai 2014 09:25:47
> *Objet: *Re: [Qgis-user] Help for QGIS-Web-Client
> Hi Amandine,
> Am 13.05.2014 09:18, schrieb Amandine SCHLOUPT:
>  > Hi Bernhard and Andreas,
>  > I thought that parameters WIDHT, HEIGHT BBOX and CRS were optional...
>  > In my browser, my layer appears like an image
> (http://localhost/cgi-bin/qgis_mapserv.fcgi?map=/usr/lib/cgi-bin/arrondissement.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=adm_arrondissement_bdt&FORMAT=image/png&CRS=EPSG:2154&BBOX=752196,6747898,1125485,6953938&WIDTH=800&HEIGHT=800).
>  > In QGIS-desktop, my project appears with my layer and I can load image.
>  > So, QGIS-Server run without error?
> If you get a map the server is fine.
>  > The CRS is defined in the QGIS project setting and also in QWC in the
>  > GlobalOptions.js. I added a file "EPSG2154.js" in
>  > ../site/libs/proj4js/defs/.
>  > What is the error ?
>  > "TypeError: wmsLoader.projectSettings.service is undefined"
>  > var thisAbstract = wmsLoader.projectSettings.service.abstractLine 1756
>  > in ../site/js/WebgisInit.js
> is Line 15 of your GlobalOptions reading:
> var useGetProjectSettings = true;
> Bernhard
> __________ Information from ESET Mail Security, version of virus
> signature database 9791 (20140512) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 9793 (20140513) __________
http://www.eset.com
