[Qgis-user] rant regarding "topology checkers"
    Zoltan
    zoltans at geograph.co.za
    Fri May 16 01:05:49 PDT 2014
Hi All,
The current thread with subject line "Re: [Qgis-user] Topology Checker
Plugin" is a perfect example of my favourite Bee that lives in my bonnet.
Firstly a BIG +1 for open source is that you CAN look at the
source-code, and there are a lot of people out there who are willing to
give you an opinion based on their experience.
The big -1 for closed source is that the methodology of any button
marked "Magically fix my data" is a closely guarded secret - so you have
no idea what it is fixing or b*ggering up.
SO, people out there, KNOW your data.
It cannot be fixed (reliably) by someone who does not know what your
data is trying to achieve.
For example: When is an overshoot a cul-du-sac and when is it an overshoot.
If the person writing the fix-up routine knows that your network is a
water network, may it will be flagged as an overshoot. If they know it
is a road network, maybe it is a cul-du-sac? But then, what if one of
the roads is attributed as a freeway?
So, the best way to fix your data is to write the feature-relationships
yourself, and to write (or run) the fixup scripts with the appropriate
parameters when possible, or not run them (the 'canned' ones) at all,
unless they give you a list of where to look, rather than quietly fixing
it the way some programmer thinks it should be fixed.
AAAARGH!
OK, I'm quiet now.
End of rant.
Regards,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax:    +27-86-6115323   www.geograph.co.za
