[Qgis-user] QGis checks uniqueness of primary key on startup
Florian Lohoff
f at zz.de
Tue May 20 05:17:23 PDT 2014
On Tue, May 20, 2014 at 11:55:51AM +0000, Andreas Neumann wrote:
> I agree - you have to put scale constraints in the symbology of an
> address table with 20 million records. Displaying all at once wouldn't
> make any sense. Most likely, every pixel of your screen would be covered
> if you want to display them all.
I have - I dont expect 20 Million object to be rendered :)
> On our cadastral map with only a couple thousand of address points we
> display house numbers from scale 2000 - otherwise you would have too
> many labels and the map gets illegible.
Thats not my problem - even on start at a scale of 1:8000 QGis does
a full table scan on that table to check for uniqueness of the key.
It does so twice by the way - once to check for uniqueness, once
to do an st_extent on the geometry ...
Flo
Florian Lohoff f at zz.de
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140520/327dcfc4/attachment.sig>
