[Qgis-user] QGis checks uniqueness of primary key on startup
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue May 20 07:17:17 PDT 2014
if a relation is a table with a unique primary key QGIS has no need to
scan for uniqueness (AFAIK)
so you could create a table or materialized view [1] (does anybody have
any experience with MV and QGIS?) to store your data and make sure that
it is always up to date
Another idea I would try is to create several views with less data each
based on the spatial index or the primary key (notice: I have not tried
if it is faster to load 20 layers à 1 million features, but it may be
faster once they are in the project)
BTW is the uniqueness scan done every time the project with the layer is
loaded or only when loading it using the load dialog?
if you find a solution please report back to the list
Bernhard
[1]
http://www.postgresql.org/docs/9.3/static/sql-creatematerializedview.html
Am 20.05.2014 15:58, schrieb Jürgen E. Fischer:
> Hi Flo,
> On Tue, 20. May 2014 at 14:17:23 +0200, Florian Lohoff wrote:
>> It does so twice by the way - once to check for uniqueness, once
>> to do an st_extent on the geometry ...
> If you don't "use estimated table data".
> Jürgen
__________ Information from ESET Mail Security, version of virus signature database 9824 (20140520) __________
The message was checked by ESET Mail Security.
http://www.eset.com
