[Qgis-user] freezing print composer on qgis 2.2.0 (64 bit) windows 7
Nyall Dawson nyall.dawson at gmail.com
Tue May 20 13:49:04 PDT 2014
On 20 May 2014 11:59, Johanna Botman <Johanna.Botman at griffith.nsw.gov.au> wrote:
> I've been experiencing this issue as well.
> It happens when I 'forget' to select between the Select/Move Item tool and
> the Move Item Content tool.
> So I could be working in the Map by panning and zooming with the Move Item
> Content tool and then click on a text box to edit that. If I have not
> selected the Select/Move Item tool when I click the text box then the whole
> lot freezes.
> I have waited for some time to see if it was a memory or refresh issue, but
> in the end, it's easier to close it down and start again. I save early and
> save often :)
Johanna,
Is this something which happens consistently for you? I've tried to
reproduce it but with no luck. Can you provide any more details on
ways to trigger issue for me?
Thanks,
Nyall
