[Qgis-user] GDAL extension, filegdb, in QGIS
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Wed May 21 00:23:21 PDT 2014
Maybe it belongs to OSGeo4W (plugin update?)?
The OGR-SOSI driver behaves comparable, and here the 32bit plugin is compiled against GDAL 1.10, while the 64bit plugin is compiled against GDAL 1.11.
In a 64bit version of QGIS 2.3, SOSI is available as a file type, in the 32bit version not. Seems plugins have to be built against exactly the same GDAL version which QGIS uses in order to be available there, which does make sense to me...
Cheers
Stefan
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Micha Silver
Sent: 21. mai 2014 08:42
To: Andre Joost; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] GDAL extension, filegdb, in QGIS
On 21/05/2014 07:22, Andre Joost wrote:
Am 20.05.2014 21:25, schrieb john polo:
André,
Your suggestion:
"This site:
<http://www.northrivergeographic.com/qgis-using-esris-file-based-geodatabase><http://www.northrivergeographic.com/qgis-using-esris-file-based-geodatabase>
suggests not to use the latest version 1.11 of filegdb, but 1.10.1-2
I have no filegdb to test it myself."
... worked perfectly for me.
I noticed on one machine (Win7 64 bit) that the gdal_ecw functionality also "went south" after an upgrade to gdal 1.11. Reverting to 1.10-4 got it back.
Should this bug go to the QGIS or the GDAL bug tracker?
greetings,
André Joost
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
This mail was received via Mail-SeCure System.
Micha Silver
GIS Consulting
052-3665918
http://www.surfaces.co.il
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140521/2ddc523c/attachment.html>
