[Qgis-user] Changing symbolsize in Printcomposer-legend
Andrea Peri
aperi2007 at gmail.com
Fri May 23 05:44:20 PDT 2014
AFAIKM something is availale in
style -> advanced -> size-scale-field -> scale area
or
style -> advanced -> size-scale-field -> scale diameter.
A.
2014-05-23 12:19 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Lene,
> Without knowing how you specified the symbol size, my assumption is that
> you used map units for the symbol size.
> Unfortunately, with map units, there is no way to influence the way the
> symbol scales in the print composer. This is a missing feature/limitation.
> If you specified the symbol size in mm it would probably look ok in the
> print composer legend.
> I don't even know how one could solve this issue - a mapping between map
> units and mm, solely for the scope of the printed legend or legend in
> QGIS WMS server?
> Andreas
> Am 23.05.2014 07:34, schrieb Lene Fischer:
> > Hi
> > In my lecture I´ve just got a question which I can´t find the solution
> for. Therefore I now try on the list -As part of teaching to use the
> mailinglist for help.
> > We use 2.2, Have made a categorized layer. Made a Printcomposer in A3
> with map and legend. But the symbols looks too small. We can change fonts.
> Tried to change Symbol Height/Width, but it only change the spacing.
> > How can we change symbolsize?
> > Regards
> > Lene Fischer
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140523/3f26e245/attachment.html>
