[Qgis-user] TIF compatibility
rob vech rob.vech87 at gmail.com
Fri May 23 08:57:47 PDT 2014
I'm running QGIS 2.2 and I'd like to load an image downloaded from here
[1] (e.g. A4B3) in TIF format.
I can see the image in Explorer in the correct way but, when I try to
load it in Qgis, the process is slow and finally only a part of the
image is shown, as if there is some sort of mask inside.
Someone experienced a problem like mine?
Now I solved importing the image in GIMP and save it again ... but I
know that it is not a good job!
Thanks
rob
[1]
http://www.cartografia.regione.lombardia.it/viewer25/index.jsp?config=config-download.xml
ps. I didn't attach the image that is too big, sorry ...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140523/56244687/attachment.html>
