[Qgis-user] how to install SciPy?
Ioakeim Tellidis
lists at e-noesis.com
Sat May 24 16:22:54 PDT 2014
The easiest way to check if you have it installed is just to open Plugins >
Python console and to type "import numpy" or "import matplotlib" without
the quotes. If the console did not complain (otherwise if you don't see
some red text coming up ;-) ) then you have it installed.
Both numpy & matplotlib along with many other things are part of what we
called Scipy. You may try this under Windows or Linux or OSX systems. It
doesn't matter the OS.
Cheers
On Thu, May 15, 2014 at 12:00 PM, Yasser López de Olmos <
biolyasser at gmail.com> wrote:
> Yes, scipy is available in OSGEO4W, at least in the 32-bit edition. Right
> now I'm using Linux, but if I remember correctly, scipy es under "libs"
> category (I'm really not sure). You should search for the "python-scipy"
> package.
> Good luck.
> El 15/05/14 05:43, Goyo escribió:
> Scipy is apparently available in osgeo4w:
>> http://download.osgeo.org/osgeo4w/x86/versions.html
>> I do not have a windows box handy to test.
>> Goyo
>> 2014-05-13 20:37 GMT+02:00 Niccolò Marchi <sciurusurbanus at hotmail.it>:
>>> Hi all,
>>> I'm looking for info for an easy way to install SciPy (on W8.1).
>>> I saw that is not present on the Osgeo installation so I tried installing
>>> another program [WinPython] containing the package but QGIS don't
>>> recognise
>>> it when necessary (e.g. using a plugin). Shall I copy libraries to a qgis
>>> folder or something else?
>>> Many thanks in advance!
>>> Nic
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140524/f002ec57/attachment.html>
