[Qgis-user] Processng - batch mode
kimaidou kimaidou at gmail.com
Sun May 25 04:56:47 PDT 2014
Hi Victor,
I recently showed the batch mode during a course on Processing, and people
had some ideas to enhance this feature. Some are feasible and pertinent,
other probably not. Here is the unfiltered list :
* allow to import/export some lines in the table (some would like csv or
even import, but I think a simple import/export tool would be enough). This
ways you could easily redo a batch job between work sessions.
* allow to add N rows at a time. for example, choose "20" then click "Add
rows" , and it will add the 20 roads
* Select a vector layer, and add a new row foreach distinct value in a field
Regards
Michael
2014-05-25 12:07 GMT+02:00 Victor Olaya <volayaf at gmail.com>:
> Double click on the column header, and it will copy the value in the first
> row to the other ones
> 2014-05-24 22:16 GMT+02:00 skampus <skampus at gmail.com>:
> ciao,
>> i often use the modules of processing in batch mode.
>> is there a way to fill in the options field of any module automatically
>> when
>> the value is the same?
>> it is not easy to enter the same value for 30 lines ....
>> thank you and ciao
>> s.
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Processng-batch-mode-tp5142353.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140525/6f3a4fcd/attachment.html>
