[Qgis-user] QGIS Opening simple Ascii X,Y,Z terrain data
Lene Fischer lfi at ign.ku.dk
Mon May 26 21:09:59 PDT 2014
Hi Rudy,
Yes for opening as raster the file need a header like this - with number of cols and rows, x,y corner, and cellsize.
You could rename a csv to asc.
But if you "only" has a csv with 3 col x,y, and z - you can take Layer>Add delimited text layer
Then make an interpolation and get your rater.
Regards
Lene Fischer
-----Oprindelig meddelelse-----
Fra: Rudy VanDrie [mailto:rudy at balancernd.com.au]
Sendt: 27. maj 2014 05:31
Til: Lene Fischer
Emne: Re: SV: [Qgis-user] QGIS Opening simple Ascii X,Y,Z terrain data
Thanks Tried that
But...
For some reason it does not want to open an ascii file with the extension ".csv" ??
Do I need to rename it ??
The file has only
X,Y,Z
No header etc....
Is that a problem??
Regards Rudy
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Lene Fischer
Sendt: 27. maj 2014 05:28
Til: Rudy VanDrie; qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] QGIS Opening simple Ascii X,Y,Z terrain data
Try to open as raster
Regards
Lene Fischer
Fra: qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Rudy VanDrie
Sendt: 27. maj 2014 04:35
Til: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Emne: [Qgis-user] QGIS Opening simple Ascii X,Y,Z terrain data
Can some one please explain how to open a simple ASCII X,Y,Z (Elevation) terrain data set ???
Why is it not straight forward ??
Regards Rudy
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140527/3c2778ad/attachment.html>
