[Qgis-user] Categorised Styling of PostGIS layers
Alexandre Neto
senhor.neto at gmail.com
Fri May 30 04:58:13 PDT 2014
That sounds still strange. Do you have space characters on your fields? I
would definitely remove them.
Either way, in Rule based symbology, you could use a rule like this:
prob like 'H%'
Alexandre Neto
On Fri, May 30, 2014 at 12:47 PM, McDonaldR <McDonaldR at angus.gov.uk> wrote:
> Hi Alexandre, Brent
> Thanks for the pointers.
> Rules based renderer failed but it work on the same data in different
> format.
> Going back to the source data (ESRI FGDB) and checking PostGIS I noticed
> the prob field was set to char(50). I reloaded the data with the field as
> varchar(50) and it now renders correctly although I still get the extra
> category added – presumably to catch blank records.
> With the data as char(50) categorisation works if I set the field with an
> expression like, TRIM(“prob”), as it then strips of the 49 blank spaces
> after the H. Varchar is better though as the table is smaller.
> Many thanks
> Ross
> *From:* Alexandre Neto [mailto:senhor.neto at gmail.com]
> *Sent:* 30 May 2014 12:01
> *To:* McDonaldR
> *Cc:* QGIS User
> *Subject:* Re: [Qgis-user] Categorised Styling of PostGIS layers
> Somehow QGIS is not finding any of those 3 values in the features in that
> extent. Can you select a few visible (pink) features and check their probability
> field values?
> Are you sure that all you features have valid values in the prob column?
> Try build that same stack of symbols using rule-based symbology. And see
> if it works.
> You can also try save a few features in other format, say a shapefile,
> open it and copy the style. See if it works there (I doubt).
> Not having access to the data, is quite difficult to understand what can
> be wrong, if you can provide a sample data, I can give a look into it.
> Alexandre Neto
> On Fri, May 30, 2014 at 11:35 AM, McDonaldR <McDonaldR at angus.gov.uk>
> wrote:
> Morning all,
> I'm trying to style some flooding probability data. It's in PostGIS and
> I'm using QGIS master (same issue in 2.0 and 2.2 though). My polygon layer
> has a probability field with values H, M and L. If I select a categorised
> style using the probability field I get the expected three values. And an
> extra one. And the data is drawn using the style of the extra category -
> in the screenshot the pink lines and not the blues as expected. If I
> delete the extra category from the classification table then nothing is
> drawn on the canvas. I have checked the field and there are only three
> unique values in it without nulls or blanks. The table is properly indexed
> with a primary key and GIST spatial index.
> So, is it a QGIS style engine problem or a PostGIS data problem? I should
> add that the same data from PostGIS draws perfectly in ArcGIS 10.2.2 and is
> styled as expected.
> Anyone else had similar experiences?
> [If the screenshot is scrubbed by the list then you can see it here:
> http://openphoto.mixedbredie.net/photo/96/view]
> *Ross McDonald *| GIS Data Coordinator | Resources Department, IT
> Division | Angus Council, Angus House, Orchardbank Business Park, Forfar,
> DD8 1AT
> T: *01307 476419* | F: 01307 476401 | E: mcdonaldr at angus.gov.uk | W: *Angus
> Maps <http://www.angus.gov.uk/maps/map_home.cfm>*
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140530/d28ccfb4/attachment.html>
