[Qgis-user] Errors in startup phase of qgis-dev should add to issue system ?
Andrea Peri
aperi2007 at gmail.com
Sat Oct 4 04:49:09 PDT 2014
I check better.
I start from an icon added to desktop from osgeo4w installer.
The icon call this:
C:\path-to-my-install-of-osgeo4w\osgeo4w\bin\nircmd.exe exec hide
C:\path-to-my-install-of-osgeo4w\osgeo4w\bin\qgis-dev.bat
I dont know what is the "nirccmd.exe"
But I assume is part of osgeo4w install.
Also I don't know what is "hide" .
The 2nd parameter:
is the qgis-dev.bat
I see on it, but no python-path env var is declared.
Perhaps the problem is the missing of the PYTHONPATH in the bat ?
I dont know how could the qgis use the python if it don't know the
pythonpath var.
I try to reinsyall all osgeo4w environment.
Thx,
2014-10-04 10:46 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> The start is from the qgis.bat installed from osgeo4w. I never set any
> variabile pythopath in window system.
> As i know all the variablres used are set directly in qgis-dev.bat.
> Perhaps an overlap done from other installed systems.
> I search for it.
> THX
> A.
> Il 04/ott/2014 10:25 "Luigi Pirelli" <luipir at gmail.com> ha scritto:
>> the error is due to your installed modules
>> as you can see: from osgeo import ogr.... No module named osgeo
>> explain you have no osgeo python module installed or it can't be find
>> in your PYTHONPATH. What did yuo changed in your previous qgis or
>> environment installation?
>> regards, Luigi Pirelli
Andrea Peri
qwerty àèìòù
