[Qgis-user] Multiple QGIS installs (Windows)
Nathan Woodrow
madmanwoo at gmail.com
Mon Oct 13 06:15:15 PDT 2014
Use the --configpath and --settings path command line options to split the
config and settings path.
Nathan
On Oct 13, 2014 11:13 PM, "McDonaldR" <McDonaldR at angus.gov.uk> wrote:
> Hi Jonathan
> Yes, you can.
> You can install the standalone version – it installs into a unique folder
> under C:\Program Files\
> You can install using OSGeo4W and install the latest stable and
> development releases into OSGeo4W\apps\qgis and qgis-dev
> However, having said this all installs (I have 2.0.1, 2.2 and 2.4 and
> 2.5dev installed) use the same .qgis2 folder in your user directory. So
> plugins that work for 2.2 but not 2.4 will show up as broken when using 2.4
> but will work in 2.2. I am not sure how you can separate out the configs
> to have separate folders or each install. Maybe some env variable?
> Cheers
> Ross
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Jonathan Moules
> *Sent:* 13 October 2014 14:02
> *To:* 'qgis-user'
> *Subject:* [Qgis-user] Multiple QGIS installs (Windows)
> Hi list,
> I was wondering, is it possible to have multiple installs of QGIS at the
> same time on a Windows box?
> I.e.:
> 2.2
> 2.4
> 2.6 (in a month)?
> Or can you only have one? And does the answer vary depending on whether
> you’re using the OSGeo installer or the standalone one?
> Cheers,
> Jonathan
> *HR Wallingford and its subsidiaries* uses faxes and emails for
> confidential and legally privileged business communications. They do not of
> themselves create legal commitments. Disclosure to parties other than
> addressees requires our specific consent. We are not liable for
> unauthorised disclosures nor reliance upon them.
> If you have received this message in error please advise us immediately
> and destroy all copies of it.
> HR Wallingford Limited
> Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
> Registered in England No. 02562099
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141013/63cb11a2/attachment.html>
