[Qgis-user] RGB pixel value
MONDOT Alexia alexia.mondot at c-s.fr
Tue Oct 14 08:41:46 PDT 2014
Hello,
With the adviced tool, you should get the values of each band on the
clicked pixel.
Else, you can use the plugin ValueTool. It displays the value of each
band of each visible raster layer under the mouse pointer.
But, as the first tool, it will display the values of each band.
(displayed with band numbers) You probably know which band is the red,
the green and the blue one.
(else, in the proporties dialog of the layer, you can check the red
green and blue band displayed)
Xan Vieiro <gallaecia6 at gmail.com> a écrit :
> Hi !!
> what I'm looking for is the Red, Green and Blue values of the pixel. For
> example a multiband satellite image.
> Kind Regards.
> 2014-10-14 10:42 GMT+02:00 Håvard Tveite <havard.tveite at nmbu.no>:
>> QGIS 2.4:
>> Select the raster layer and choose "Identify Features"
>> (button with a white "i" in a blue filled circle on it).
>> Then click on the pixel.  The value(s) will be displayed
>> in the Identify results window.
>> Håvard
>> On 2014-10-14 1:48, Xan Vieiro wrote:
>>> Hi !!
>>> How can I know the RGB value of a single pixel?
>>> Thanks.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Håvard Tveite
>> Department of Mathematical Sciences and Technology, NMBU
>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>> Phone: +47 64965483 Fax: +47 64965401 http://www.nmbu.no/imt/
This message was sent using IMP, the Internet Messaging Program.
