[Qgis-user] Python for .NET in QGIS
Gang Yang
gang.yang at freenet.de
Fri Oct 17 06:19:22 PDT 2014
Hello!
I installed Python for .NET and have no problem to make my standalone Python
console (version 2.7) ".NET-aware": the .NET DLLs can be called from the
console without problem.
I thought this could be done also for QGIS Python console on the same pc:
1. I copied the two files of Python for .NET: clr.pyd and
Python.runtime.dll to the qgis folder:
C:\Program Files\QGIS Chugiak\apps\Python27
to assure these two files to be included in the sys.path;
2. In QGIS Python console I typed:
Import clr
Here I got the error:
File "<input>", line 1, in <module>
File "C:/PROGRA~1/QGISCH~1/apps/qgis/./python\qgis\utils.py", line 454, in
_import
mod = _builtin_import(name, globals, locals, fromlist, level)
SystemError: dynamic module not initialized properly
My question: Is this the correct way to make pyqgis to .NET-aware? Or the
qgis python is something special so that it is not possible to do this?
Thank you in advance.
Gang
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141017/c45ab2bc/attachment.html>
