[Qgis-user] Export WKT format
Alex Mandel tech_dev at wildintellect.com
Mon Oct 20 11:31:17 PDT 2014
KML isn't a good choice, as it's always Lat/Lon WGS84.
GML might work, but give GeoJson a shot first - it's simpler than GML to
parse (actually little or no parsing required).
Did you try ogr2ogr on the commandline to make sure it's not a bug in
the QGIS writer for long lines?
Thanks,
Alex
On 10/20/2014 11:11 AM, Andrew Gillett wrote:
> I wrote my parser for WKT as it was the quickest and simplest format to
> parse that I was aware of – I only need the country border data, and
> could see how to parse this just by looking at the file, whereas other
> formats would have needed more research.
> The problem is with exporting the WKT using a specified projection. At
> the moment I have to export an intermediate format to get the projection
> right, then load that back in and copy/paste for the WKT.
> I am now looking into using KML or GML instead.
> On 20/10/2014 18:26, Alex Mandel wrote:
>> That sounds like it's hitting some sort of line limit. Might be a bug in
>> OGR. You could try writing WKT to a column first, but it would have to
>> be in a layer type that supports long text fields.
>> That said WKT is not a great format for complex geometries. Perhaps you
>> can tell us your goal and we can suggest another way to get there.
>> Thanks,
>> Alex
>> On 10/20/2014 10:21 AM, Andrew Gillett wrote:
>>> Thanks for the info. I've just tried this and there appears to be a bug
>>> in it. I'm using the country border data from here:
>>> http://www.naturalearthdata.com/downloads/10m-cultural-vectors/
>>> If, for example, I select Iceland and export as you suggested, the
>>> column for the polygon data is truncated. Only about 200 vertices are
>>> exported, as compared to around 3000 which are correctly present if I
>>> use the copy/paste method. The polygon data ends with an X coordinate
>>> but no Y coordinate, and the closing brackets and quote mark are also
>>> missing.
>>> On 20/10/2014 17:39, Matthias Kuhn wrote:
>>>> Hi Andrew,
>>>> WKT is a format for geometries and not a file type. Therefore it is not
>>>> possible to offer a save as WKT just like that. You can however easily
>>>> choose Comma Separated Value as export format and then choose AS_WKT in
>>>> the Geometry combobox under layer options.
>>>> Best regards,
>>>> Matthias
>>>> On 20.10.2014 18:35, Andrew Gillett wrote:
>>>>> It is possible to export in WKT format by copying then pasting into a
>>>>> text editor. However, there is no WKT option when exporting via Layer
>>>>> -> Save As. Is there a particular reason for this, or is there a
>>>>> development list where I could request this?
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Alex Mandel
http://wildintellect.com
