[Qgis-user] Vectors data and raster with same projection didnot overlap
Andre Joost andre+joost at nurfuerspam.de
Wed Oct 22 08:16:38 PDT 2014
Am 22.10.2014 um 15:11 schrieb Yada Elisabeth:
> Dear Mark,
> the vectors data are basemaps with this CRS:
> PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],PARAMETER["Standard_Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0]]
>>> I have a set of vector data and raster data I reproject in the same CRS
>>> (EPSG:32631 ;
How did you reproject the vector data to EPSG:32631?
Rightclick -> "Set CRS for layer" is NOT the right way to do it.
Greetings,
André Joost
