[Qgis-user] error_ R_home range
Emiliano Manzo emiliano.manzo at ethoikos.it
Wed Oct 29 06:30:53 PDT 2014
Hi
i have tried to use R home range, i have installed adhabitat on R and after i had tried to run h kernel but i received this error message and i don’t know what i can do.
I used Mac os X Qgis 2.4
Oooops! The following output layers could not be open
Home_ranges: /var/folders/zw/bp2757r12_s4_rryzp2fjblw0000gn/T/processing/eb692106bf2b4c75b891f7cd3a67c6bc/Homeranges.shp
The above files could not be opened, which probably indicates that they were not correctly produced by the executed algorithm
Checking the log information might help you see why those layers were not created as expected
This algorithm requires R to be run. A test to check if R is correctly installed and configured in your system has been performed, with the following result:
R seems to be correctly installed and configured
The script you have executed needs the following packages:
adehabitatHR
Make sure they are installed in your R environment before trying to execute this script.
Is anybody can help me?
Thank you
Emiliano
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141029/174d0362/attachment.html>
