[Qgis-user] Help with Ordnance Survey SLD's for OS Mastermap
Thomas Colley
t.colley at neath-porttalbot.gov.uk
Mon Sep 1 01:34:56 PDT 2014
os_cat is a field used for styling in OS layers. The complication is (at least last I checked) the field doesn’t exist in the data as shipped. There are some SQL files on the OS website for creating os_cat (calculated from a combination of other fields) in PostGIS, but I’m not sure how that would be applied to shapefiles.
I’m sure that OS have released proper QGIS Style Files now as well as SLDs. I can’t find them at the minute (too early on a Monday morning) but I’ll let you know when I do.
Cheers
Tom
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Giuseppe Sucameli
Sent: 01 September 2014 08:34
To: David James
Cc: qgis-user ML
Subject: Re: [Qgis-user] Help with Ordnance Survey SLD's for OS Mastermap
Hi David,
IIRC that kind of variables are not supported by QGIS neither by the SLD standard.
You must replace it with the correct SVG filename.
Anyway, what is "os_cat" supposed to be? Is it a layer's field name?
Regards.
Sent from mobile. Sorry for being short.
Giuseppe Sucameli
Il 01/set/2014 00:01 "David James" <david at djames.org.uk> ha scritto:
I'm very much a beginner with QGIS and I'm trying to run long before I
can crawl ...
I'm trying to use the Ordnance Survey MasterMap Topography layer SLD's
(from
http://www.ordnancesurvey.co.uk/docs/styled-layer-descriptors/topography-sld.zip)
to style the sample OS MasterMap data.
Initially, I found that when I loaded the SLD file into QGIS, only the
first rule was being picked up, but eventually I found tjmgis's answer
in
http://gis.stackexchange.com/questions/69854/styling-os-vectormap-local-in-qgis
(that all the <FeatureTypeStyle> and </FeatureTypeStyle> except the
first and the last in the SLD files need removing) and now I'm making
progress.
I'm struggling with one problem: there's a rule called
<Name>Vegetation (pattern) - 1:35 to 1:3,496</Name>
which specifies the SVG file as
xlink:href="osmmsymbols/${os_cat}.svg"/>
QGIS is showing me question marks in these areas (which I think means it
is not finding the SVG file).
Does QGIS support this use of ${os_cat} (and if so, what do I need to do
to make it work?) or do I have to replicate the rule with explicitly
named SVG files for all the different vegetation types?
David
David James
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140901/20522d6b/attachment.html>
