[Qgis-user] Editing - table mask - Insert values from near features from other layer
Damien Stephens
Damien.Stephens at sandfire.com.au
Thu Sep 4 17:14:33 PDT 2014
My suggestion would be to try using the buffer tool in vector/geoprocessingtools.
This automatically creates buffers around your discharge point at set distances. You could then use these to select areas within those radii and assign attributes?
Cheers
Damien
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Pietro Rossin
Sent: Thursday, 4 September 2014 5:06 PM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Editing - table mask - Insert values from near features from other layer
Ok the title is a little odd...
But
let's say I have a postgis feature layer in editing session with qgis.
This layer is for example the discharging point of a waste water treatment plant.
The waste water treatment plants data and geometries are on a second postgis layer.
I would like to enter the data relative to the discharge point and make some fields that are drop down list of attributes taken from the WWTP (the other layer - plants) using a proximity criterion?
Is it possible using table mask in Qgis?
Thanks
Pietro
View this message in context: http://osgeo-org.1560.x6.nabble.com/Editing-table-mask-Insert-values-from-near-features-from-other-layer-tp5160031.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
