[Qgis-user] QGIS Using Size-Scale Field
kmithoefer
kmithof at gmail.com
Fri Sep 5 08:33:48 PDT 2014
Dear Andreas,
Thanks a lot! Perfect, I didn't know that.
Best regards and good weekend
Klaus
Am 05.09.2014 13:28, schrieb Andreas Neumann [via OSGeo.org]:
> Hi Klaus,
> This is very simple to achieve. Just use the alpha value in the fill
> color and set it to zero.
> Andreas
> Am 05.09.2014 10:17, schrieb kmithoefer:
> > Dear list,
> > I want to map point data with insect species density and want to use
> the
> > percent values from a table as the size-scale field to map points of
> > different size representing the densities. I followed this
> instruction (
> http://horta.ulb.ac.be/cours/SIS-TP-Tutoriels/QGIS%20Tutorials%20%28Ujaval%20Gandhi%29/qgis.spatialthoughts.com/2012/02/styling-vector-data-in-qgis-using-size.html
> <http://horta.ulb.ac.be/cours/SIS-TP-Tutoriels/QGIS%20Tutorials%20%28Ujaval%20Gandhi%29/qgis.spatialthoughts.com/2012/02/styling-vector-data-in-qgis-using-size.html>
> > ) and used the simple marker. This worked so far. But what I would
> like to
> > do is mapping only the outline of the marker without any filling
> colour to
> > see the vegetation below. Is this possible? I need to do this to
> overlay
> > different species densities in different colour mapped as circles.
> Therefore
> > applying transpareny to the layer or symbol does not help because
> this is
> > also applied to the outline. Has anyone an idea on how to map circles
> > without filling color?
> > I am very thankful for any comments.
> > With regards
> > Klaus
> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Using-Size-Scale-Field-tp5160298.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > [hidden email] </user/SendEmail.jtp?type=node&node=5160322&i=0>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email] </user/SendEmail.jtp?type=node&node=5160322&i=1>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Using-Size-Scale-Field-tp5160298p5160322.html
> To unsubscribe from QGIS Using Size-Scale Field, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5160298&code=a21pdGhvZkBnbWFpbC5jb218NTE2MDI5OHwtMjc0MTE4MjQ3>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
kmithof.vcf (233 bytes) <http://osgeo-org.1560.x6.nabble.com/attachment/5160382/0/kmithof.vcf>
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-Using-Size-Scale-Field-tp5160298p5160382.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140905/af0abab0/attachment.html>
