[Qgis-user] Check geometry validity tools
Matt Boyd
mattslists at gmail.com
Fri Sep 5 09:58:24 PDT 2014
If you can't select that feature, can you select everything else and save
the selection as a new file?
On 05/09/2014 6:07 pm, "Alessio Degioannini" <a.degioannini at proterstudio.com>
wrote:
> Hi All,
> as i have written in the first message, the polygon is a ring with less
> then 4 points...
>> You may try to correct the invalid feature with the PlainGeometryEditor
>> plugin: https://plugins.qgis.org/plugins/plaingeometryeditor/
>> Here you can manually edit each ring and vertex by manipulating the
>> coordinates in a text-field.
> The polygon is not selectable, also in PlainGeometryEditor.
> Alessio
> Alessio Degioannini - dottore forestale
> PROTER - Studio Associato Agronomico e Forestale
> C.so Stati Uniti, 27 - 10128 TORINO (ITALY)
> Tel: +39 011 817 0767
> Fax: +39 011 070 2382
> Cell.: +39 329 211 2781
> E-mail: a.degioannini at proterstudio.com
> P.E.C.: a.degioannini at epap.conafpec.it
> Il 05/09/2014 09:13, Bernhard Ströbl ha scritto:
>> Hi Andreas,
>> you maybe right. However we do not know :-) . I was under the impression
>> it is a simple polygon with only one ring with less than 4 points. ring0 is
>> the first (and if it is a plain polygon the only) ring, isn't it?
>> Bernhard
>> Am 05.09.2014 09:00, schrieb Andreas Neumann:
>>> I think that Alessio is trying to select an invalid ring within a
>>> polygon or multipolygon. This is not possible in the table.
>>> Hope this helps,
>>> Andreas
>>> Am 05.09.2014 06:55, schrieb Bernhard Ströbl:
>>>> Hi,
>>>> if you cannot select it graphically you should select it in the table
>>>> Bernhard
>>>> Am 05.09.2014 08:48, schrieb Alessio Degioannini:
>>>>> Yes.
>>>>> Il 05/09/2014 08:02, Hakala Oiva (MTT) ha scritto:
>>>>>> Have you enabled editing?
>>>>>> Oiva
>>>>>> Well: now i'm trying to select it for delete it, but it seems
>>>>>> impossible....
>>>>>> Someone can help me?
>>>>>> Best regards.
>>>>>> Alessio
>> __________ Information from ESET Mail Security, version of virus
>> signature database 10369 (20140905) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140906/e76e9ea0/attachment.html>
